12/24 hour setting in Newton 5/6
Zoltan
Post by Zoltan »
I do remember that in fw 4.xx 12/24 hour was in User sequence.
But how to switch from 12 hours (am/pm) to 24 hours if one is over fw 4.xx? In Fw 5/6 there is no User sequence any more.
And it seems that applying metric from english with Isaac (set units) has no effect on 12/24.
Re: 12/24 hour setting in Newton 5/6
We have not updated Newton FW since 2014, when we eliminated the User sequence.
You'll need to do these kinds of corrections in Isaac.
Zoltan
Post by Zoltan »
Sorry, John, I meant where to do it in Isaac? Simply changing English to metric has not changed 12h to 24h. Is there any other place within Isaac (latest version is installed) where I can make the correction?
You can repair the date/time of a ride file in Isaac using the command below.
You can change Newton ENGLISH/METRIC settings from Isaac.
Screen Shot 2019-01-28 at 10.35.53 AM.png (616.7 KiB) Viewed 38031 times
Screen Shot 2019-01-28 at 10.29.19 AM.png (157.11 KiB) Viewed 38032 times
Zoltan
Post by Zoltan »
Then I am stuck, because the function you nicely point to is the one I used without any effect on 12/24h. The units of all the other measures like those of elevation, weights and distance are correctly changed to metric.
Zoltan wrote: Mon Jan 28, 2019 10:49 am Then I am stuck, because the function you nicely point to is the one I used without any effect on 12/24h. The units of all the other measures like those of elevation, weights and distance are correctly changed to metric.
This is by memory only, but I do not believe we ever implemented 12/24H time. In any event yes, you are stuck :(
