I received my repaired PowerPod back last Friday. I am assuming that I have been sent a refurbished PowerPod as a warranty replacement as the PowerPod I received was not my original PowerPod?
Since refitting and re-calibrating this PowerPod I have been experiencing issues whereby the readings drop down to 0w (sometimes for up to 30 seconds) before gradually climbing back up to (what I assume) are the correct readings. This happens on the flat or inclines so not related to elevation.
My calibration ride was done in windy condition so after my initial ride I tweaked the Profile wind scale factor back to my original (pre- warranty replacement) wind scale factor. I assume that this will not cause 'drop-out' issues.
I have attached 3 recent files for reference. Part of the attached is stop-start riding in traffic, however there are several miles on the attached whereby my ride is completely uninterrupted by traffic which will give better idea of the issue.
Please can you review the attached and advise.nb, There are no physical obstructions to the windport that could be responsible.
Thanks for any help in advance,
Steve
Issues with Repaired PowerPod
stevepmoore
- iBike_01_21_2019_1831_19_Miles.ibr
- (218.78 KiB) Downloaded 381 times
Re: Issues with Repaired PowerPod
Only 1 file was attached. Please attach the others.
If you have an older file, from before your PP was repaired, please attach that too, and mark it so we will know!
stevepmoore
John,
Apologies, I must have unattached 2 of the files between Preview and Posting.
Attached are the 2 other files plus a Pre-Repair file. I am not sure how much help the pre-repair file will be as it is a) A different PowerPod to my original and b) A different bike - as I am now using my winter bike. I am afraid that I don't have any pre-existing files for my winter bike as I had already put it away last year for the summer before I bought the PowerPod.
Thank you,
Stephen
Thank you,
Stephen
- iBike_01_22_2019_1801_18_Miles.ibr
- (216.22 KiB) Downloaded 327 times
stevepmoore
Ok, for some reason I can only attach one file at a time, so will attach the others in separate posts.
- PRE-REPAIR-iBike_11_18_2018_0637_51_Miles.ibr
- (514.19 KiB) Downloaded 334 times
stevepmoore
.........and finally.
- iBike_01_22_2019_0804_12_Miles.ibr
- (140.08 KiB) Downloaded 287 times
I'm really sorry to say this, but it appears that your PP was not calibrated correctly at the factory. You will need to return it to us for recalibration. Please contact technicalsupport@velocomp.com for next steps.
stevepmoore
Not what I was hoping to hear, but thanks John.
I'll email them now.
Yeah, we are really sorry too.stevepmoore wrote: ↑Thu Jan 24, 2019 9:43 am Not what I was hoping to hear, but thanks John.
