Sensor cadencia
Matteo
Sensor cadencia
Post by Matteo »
Hola
Mi pregunta es...se puede poner el mismo sensor de cadencia en dos bicicletas distintas??una de montaña y la otra de road?
Gracias
Re: Sensor cadencia
Yes, you can use the same cadence sensor on two different bikes. You will, of course, need to have two different profiles, and you will need to pair the cadence sensor to both of those profiles.
Make sure to use a DIFFERENT speed sensor for each bike, so that your device will automatically be able to switch between bikes.
