Aeropod calibration trouble
Kai Matsui
Post by Kai Matsui »
I have some trouble about initial calibration.
Let me ask some question.
I have read the following materials and video
AeroPod_TIPS_TROUBLESHOOTING111618.pdf
Aeropod_Basic_Setup.pdf
https://www.youtube.com/watch?v=198XSnl6gnA
I have done the initial sensor pairing with ANT+ sensors
which are DFPM (with “built-in”r cadence sensor) and a speed sensor successful.
The light was Flashing green at first, then 3 flashes of yellow and
Solid green at end of pairing, then light goes out.
Then, I have moved to calibration process and I had some troubles.
At first, I have click the button then the light "solid yellow"
which means 7.calibration (at "Aeropod_Basic_Setup.pdf") steps successful.
But next step, 7A RED/GREEN Flashing was never happened.
I try to ride the bike for a few seconds, but NO "RED/GREEN Flashing"
Only the light "solid yellow" have continued.
I have continued the calibration process and click the button.
Paired Germin 1000 & IQ apps shows watts slowly climb,
and 1w to 50w but it never stop, and rising up to 100w.
At 50w, no “frozen” and no "Solid red" light and "Flashing yellow".
I see that the calibration process have some trouble and I tried
these procedure 10 times but these situation were same,
NO " RED/GREEN Flashing" at procedure "7A".
Would you please let me know what happened in my AeroPod.
What should I do?
If you need the more information, please let me know.
I'll send you additional informations.
Kai Matsui
Re: Aeropod calibration trouble
Make sure AeroPod is set to profile 4.
Press-hold AP button for about 12 seconds. After 4 seconds it will start to flash, but keep holding it until the light goes out momentarily, then starts flashing again. Release the button. This does a hard reset of your device.
Please post a .ibr ride file from your device.
Kai Matsui
I have tried to the hard reset which you mentioned and calibrated Aeropod successfully.
Thank you for your cooperation.
I will try using analysis software "Newton" from now.
