Newton +6 : help with Avg Watts
Ridley
Post by Ridley »
I live in Italy, last month I bought a Newton +6 and I think to have a problem with the watts.
After I did the Cal ride, the FTP test and a short ride of 41 km I checked the watts :
Cal ride = 5,8 km 32,9 km/h 259W
FTP test = 13,2 km 39,2 km/h 340W
Short ride = 40,6 km 35,2 km/h 318W
Undoubtedly too high values on watts.
I post all the .ibr ride files and I hope someone will take a look
Corrado
iBike_10_08_2018_1338_6_km_CalRide.ibr
(96.71 KiB) Downloaded 783 times
iBike_10_12_2018_1331_14_km_HiDef.ibr
(179.11 KiB) Downloaded 871 times
iBike_10_14_2018_1320_41_km_HiDef.ibr
(559.78 KiB) Downloaded 833 times
Re: Newton +6 : help with Avg Watts
1) You have a PowerPod, not a Newton (I can tell by the serial number)
2) Your profile setting is incorrect; your rolling resistance is way too high, causing your problems
3) Load the attached profile into your PP and all will be well
4) Corrected files are attached.
5) Your powerstroke shows a LOT of side-to-side sway. You are a very strong cyclist, but you might want to focus some on improving your sway
Ridley.ibp
(418 Bytes) Downloaded 815 times
Ridley_corr_10_14_2018_1320_41_km_HiDef.ibr
(579.7 KiB) Downloaded 805 times
Ridley_corr_10_12_2018_1331_14_km_HiDef.ibr
(185.8 KiB) Downloaded 831 times
Ridley
Post by Ridley »
Thank you for your prompt replay,
1) I swear I have a Newton +6 not a PowerPod
2) I noticed that my rolling resistance was way too high and now you have confirmed it.
3) Which is the name of the attached profile to load in my Newton? Is this profile suitable for my Newton? How can I load the attached profile on my Newton?
4) Ok
5) About my sway you are right because I have an injury to anterior cruciate ligament of my right knee. I have to work a lot on this!
Corrado
PS: I see that you didn't download the Cal ride, did you have some problems?
1) My mistake! I read the serial number improperly; you do have a Newton... :-)
2) Profile ends in .ibp. Place .ibp profile on your desktop. Attach Newton to Isaac. Go to "Edit/Edit Profiles". Click the "Import" button. Then click "Send to Device"
3) I don't need to download the cal ride, because your subsequent rides have the cal ride profile embedded in them
4) You sure are a strong cyclist, even after your injury!!!
