Just completed a windy 52 mile ride.
Everything appeared to be functioning normally between my Garmin Edge 1000 and PP. Power, HR, Speed & Cadence were displaying and looked ok but when I uploaded to Isaac there was no cadence for the first 27 miles then it was recorded and displayed accurately.
PP was paired with Garmin from the start and cadence and Power displayed within about 10 seconds of starting the ride.
Any suggestions as to why the 27 miles cadence might not have recorded and what might have triggered it to start recording?
I've attached the file if anyone can delve into it.
Cadence not showing in Isaac
- iBike_11_08_2018_1018_52_Miles.ibr
- (885.42 KiB) Downloaded 726 times
Re: Cadence not showing in Isaac
1) If you have your ride file recorded in your Garmin, export it in .tcx format, then merge it into your Isaac file. You can import the cadence data in this manner
2) At the beginning of a ride, PP "looks" for cadence data for a while. If it does not find it after a period of time PP stops looking. Where your cadence data resumed appears to be after a PP lost your speed signal for 6 seconds. Most likely PP started looking for the cadence signal when speed dropped out
3) Do a hard-reset of your PP. This MAY prevent this from happening again.
Thank you John.
It worked. Learned something new.
