Can't connect iAero to computer
jbox2004
Post by jbox2004 »
I just recieved a new iAero and have followed all the instructions for setting it up but cannot get my computer to connect to my iAero. I've downloaded the drivers but still no luck. Any advice would be greatly appreciated.
Jess
Re: Can't connect iAero to computer
Operating system?
When you click on device... connect... do you see something like this?
You want to see a com port that shows Silicon Labs Drivers.
Make sure your iAero is on.
Provide more info and we should be able to get you going.
alback
Post by alback »
I had the same issue with my iAero in WinXP pro. I did a search on the Net for similar issues and found that using a previous CPA210 driver worked for some. Mine has worked ever since.
My driver is now 4.28.0.2700 from 2004 - not sure if this was updated with ibike 2.08 or not but it hasn't failed since.
Hope this helps.
Alan
