Help with data transfer to Cycling Peaks
I'm brand new to iBike, just did my coast downs and calibration ride. Went out for a ride, and I'd like to start playing around in Cycling Peaks. I've read the posts I can find on this board which suggest doing your ride analysis in iBike2, saving the file, and then uploading into Cycling Peaks, either by "File -> Open" or dragging the file onto the open application.
The problem I'm experiencing is that when doing either of the above, I see no data whatsoever in the 9/21 file in Cycling Peaks. No Speed, no Power, no anything. I realize that I'm probably making some fairly obvious rookie mistake, but for the life of me I can't figure out what it is. Any suggestions would be greatly appreciated!
-M
-M
Re: Help with data transfer to Cycling Peaks
Open CP, click on file, click on open workout,... a small box should open, at the top you should see "look in", click once on the file folder icon, a drop down menu should appear, bring up your ibike ride files (mine are located in MY DOCUMENTS, so I open that folder, then click on your "ride file", what ever the file is named, then open that... near the bottom of the box. That should open the ride file in CP.
Hope this works for you.
Regards,
Howard
Regards,
Howard
One more consideration:
WKO always starts to look for files in its own directory first (at least it does for me). So you have to navigate a tree to get to your directory. That can be convoluted depending one where you keep your iBike files. Since WKO also supports drag and drop, if you have a window open showing the contents of the iBike ride folder then you can click on your file or files, drag and drop them on to WKO. You'll select the athlete and you're done.
I use WIN XP SP2, so VISTA may be different but the drag and drop should still work.
thanks both Howard and Fernando for the posts. I'm able to find the iBike file and select it to load. The problem I have is that when I do open it in Cycling Peaks (either by File -> Open, or through drag and drop), the workout file shows up in Cycling Peaks (I see that there's a workout in the calendar), but there's no data for the analysis (power, speed, etc ). When I open the same file in Excel, there's plenty of info there, but it's not showing up in Cycling Peaks.
Thanks for any suggestions you might have!
-M
-M
And this is with a post-analysis file? Could you upload one of your ride files please.
Just to confirm, you're using the PC version WKO+ correct? You get nothing in the graph, nothing on CP1m or any other data at all? So what shows in the calendar, the activity on the date without TSS or IF?
Weird.
Weird.
You're correct, a post-analysis file, loading into Cycling Peaks, which shows up in the calendar as a workout, but no TSS, no IF, no speed or power data at all. I'm including the file from the ride here. Thanks so much for your help in figuring this out!!!
-M
-M
- iBike_09_21_2008_1120_8_Miles.csv
- (182.21 KiB) Downloaded 595 times
You may an old version of WKO+. I loaded your file and got expected results including TSS and IF. Attached is the .wko file that you should be able to open. The latest build is v2.2 build 96.
FYI, the data I can see is power, speed, wind, altitude and slope. You must have an original wired sensor without cadence.
NOTE: Remove the .csv from the file name before trying to open it in WKO. I had to do that in order to bypass the upload restriction on this forum.
- iBike_09_21_2008_1120_8_Miles.wko.csv
- iBike_09_21_2008_1120_8_Miles.wko is the real file name
- (83.49 KiB) Downloaded 602 times
That must have been the case. Thanks for all the help!!!
-M
-M
I have a new GEN III iAero wired version and I am having trouble accessing data with Cycling/Training Peaks. I downloaded the trial version of the latest Cycling Peaks software but Cycling Peaks won't automatically download the data from the iBike. I hit the Start Download but it hangs on the Polling device for information and doesn't seem to connect to the iBike. I do have it set in Cycling Peaks under the Application Settings correctly with the iBike information and COM port. Does anyone know of any limitations with the Trial version of Cycling Peaks? It is suppose to be a full version valid for 14 days.
I can open a csv file created from the iBike software but when I open the file there is ride information (miles and speed) but no power/watts information. The same is true if I drag and drop the file into Cycling Peaks.
Any ideas for these issues?
I have the latest iBike3 software and firmware for the device.
To get the power to read when opening a .csv file you first need to open the .csv file in excel and change the column name DFPM Power to anything else, save it, close the file then open it up in wko+
Chris
Chris
I vaguely remember that Training Peaks (hereinafter referred to as WKO) had trouble downloading from an iBike directly.
Try the following:
Open the iBike CSV file with Excel and go to column "L" Row 5. It should say DFPM Power.
In that same cell, type the word "BLANK", hit enter and click on save. You get the usual warning about saving as a csv file.
Save the csv file, exit Excel and do not save when asked a second time.
Now try dropping the file or opening with WKO. Either way.
FWIW, when I import my wireless data into WKO I get ALL the data fields including wind.
Let me know,
Try the following:
Let me know,
Thank you Chris and Fernando, modifying the .csv file worked.
I just got a email from Trainingpeaks with a new build 100 to fix the no power displaying. I followed the update link within the software update link but is still showing build 99. I guess I was early or at the wrong page??
Ty
travispape
- Site Admin
I've tried the build 100 and it works fine. Actually, I wasn't aware that it isn't posted yet--I tried the update feature and found that their latest post is 99 just like you found. I know their developer has been out of town--he did the build 100 on the road.tyhaar wrote:I just got a email from Trainingpeaks with a new build 100 to fix the no power displaying. I followed the update link within the software update link but is still showing build 99. I guess I was early or at the wrong page??
Travis
Tom_Anhalt
Hmmm...I'm only using build 96 of WKO+ and I've had no problem just "dragging and dropping" either Gen II or Gen III iAero files into it and having all the data show up (with no file manipulations whatsoever required)...travispape wrote:I've tried the build 100 and it works fine. Actually, I wasn't aware that it isn't posted yet--I tried the update feature and found that their latest post is 99 just like you found. I know their developer has been out of town--he did the build 100 on the road.tyhaar wrote:I just got a email from Trainingpeaks with a new build 100 to fix the no power displaying. I followed the update link within the software update link but is still showing build 99. I guess I was early or at the wrong page??
Travis
Now then, being able to load and synch a Garmin .tcx file (CinQo power recording) into iBike3 is another story
Confirmed and agreed on both counts. Build 96 works fine. I haven't seen anything in the newer builds that applies to improved functionality within WKO. The changes involve uploading to their web version. They're putting so much effort into the web version, I wonder if any more "real" development will ever come to WKO. You can go back to build 96 by clicking here: http://www.cyclingpeakssoftware.com/lin ... o22B96.exeTom_Anhalt wrote: Hmmm...I'm only using build 96 of WKO+ and I've had no problem just "dragging and dropping" either Gen II or Gen III iAero files into it and having all the data show up (with no file manipulations whatsoever required)...
I cannot combine Garmin data with iBike files as of late. I just sent Travis an email with a ride file. I think it has something to do with the latest FW version of the 705. It used to work fine and I don't think it's the iB3 software. We'll see.
travispape
- Site Admin
Up until recently, WKO would ignore the DFPM Power column in the iBike CSV file. The recent change for WKO (maybe it started with build 99--I'm not sure) is that their iBike CSV parser started picking up the DFPM Power data if present. The problem is that if you don't have a DFPM signal, the CSV column has zeros and WKO was picking up those zeros. Starting with build 100, it properly ignores a column of zeros and uses the regular Power column.Tom_Anhalt wrote:Hmmm...I'm only using build 96 of WKO+ and I've had no problem just "dragging and dropping" either Gen II or Gen III iAero files into it and having all the data show up (with no file manipulations whatsoever required)...
Travis
Tom_Anhalt
Aaah...I see. I've been taking the iAero files into WKO+ mainly to look at the iAero power calculation, and since I've been running it with the CinQo, there's always power values in the DFPM column. If I want to look at how it records the CinQo data I just open the .csv file and copy the DFPM column into the power column and save the .csv to a different name...and then just drag and drop that into WKO+.travispape wrote:Up until recently, WKO would ignore the DFPM Power column in the iBike CSV file. The recent change for WKO (maybe it started with build 99--I'm not sure) is that their iBike CSV parser started picking up the DFPM Power data if present. The problem is that if you don't have a DFPM signal, the CSV column has zeros and WKO was picking up those zeros. Starting with build 100, it properly ignores a column of zeros and uses the regular Power column.Tom_Anhalt wrote:Hmmm...I'm only using build 96 of WKO+ and I've had no problem just "dragging and dropping" either Gen II or Gen III iAero files into it and having all the data show up (with no file manipulations whatsoever required)...
Travis
Soo...you're saying that if there's zero power values in the DFPM column, with build 100 of WKO+ the DFPM power will be ignored and the regular iAero power will be displayed in WKO+. Got it. But, if there's DFPM power values, does it just take that column? What if you want to look at the iAero values in WKO+ as well? Do you have to go in and manually erase the DFPM column and drag it in again? If so, it doesn't seem like there's been much of an improvement since Build 96...you still end up cutting and pasting columns to look at one or the other
BTW, when I used the "Check for new version" function of WKO+, it sent me to the TP site and it still only had build 99 as the latest. Do you know yet how one can get a hold of build 100? Thanks!
Tom_Anhalt
Hmmm...I'm pretty sure it's not an issue with the 2.50 version of the Garmin firmware (i.e. the latest). I had updated the 705 I'm using to that and was able synch up .tcx files from the Garmin in the iBike2 software just fine. It wasn't until I rev'd up to iBike3 that I couldn't get it to synch very well. For example, on Tues., the first half of the ride, as brought into iBike3, looks nothing like what it's supposed to...and how it looks WKO+.racerfern wrote:Confirmed and agreed on both counts. Build 96 works fine. I haven't seen anything in the newer builds that applies to improved functionality within WKO. The changes involve uploading to their web version. They're putting so much effort into the web version, I wonder if any more "real" development will ever come to WKO. You can go back to build 96 by clicking here: http://www.cyclingpeakssoftware.com/lin ... o22B96.exeTom_Anhalt wrote: Hmmm...I'm only using build 96 of WKO+ and I've had no problem just "dragging and dropping" either Gen II or Gen III iAero files into it and having all the data show up (with no file manipulations whatsoever required)...
Travis, if another set of ride files would help, just let me know and I'll send them along.
travispape
- Site Admin
Tom & Fernando,Tom_Anhalt wrote:Hmmm...I'm pretty sure it's not an issue with the 2.50 version of the Garmin firmware (i.e. the latest). I had updated the 705 I'm using to that and was able synch up .tcx files from the Garmin in the iBike2 software just fine. It wasn't until I rev'd up to iBike3 that I couldn't get it to synch very well. For example, on Tues., the first half of the ride, as brought into iBike3, looks nothing like what it's supposed to...and how it looks WKO+.racerfern wrote:Confirmed and agreed on both counts. Build 96 works fine. I haven't seen anything in the newer builds that applies to improved functionality within WKO. The changes involve uploading to their web version. They're putting so much effort into the web version, I wonder if any more "real" development will ever come to WKO. You can go back to build 96 by clicking here: http://www.cyclingpeakssoftware.com/lin ... o22B96.exeTom_Anhalt wrote: Hmmm...I'm only using build 96 of WKO+ and I've had no problem just "dragging and dropping" either Gen II or Gen III iAero files into it and having all the data show up (with no file manipulations whatsoever required)...
The problem is with the <track> flags in the TCX file. Garmin keeps changing their mind about what triggers their appearance in a TCX file. I started handling them in the parser, but then they changed the format. Anyway, the next build of iBike3 will be able to handle the issue.
In the mean time, all you have to do is open your TCX files in Notepad and search for all occurances of "</track><track>" and replace them with "" (empty string). I tried it and it works for both of your files.
Travis
Tom_Anhalt
Thanks Travis! That explains a lot...
travispape
- Site Admin
Keep checking. I'm told that the new build should appear "soon".Tom_Anhalt wrote:BTW, when I used the "Check for new version" function of WKO+, it sent me to the TP site and it still only had build 99 as the latest. Do you know yet how one can get a hold of build 100? Thanks!
