Aeropod working only 5% of time
Johan
Post by Johan »
Hello i just received my Aeropod, i think i've done all the initial set-up in the right way :
- charging
- installing issac on mac
- set-up profile 1
- mount on the bike
- pair with bike pod (bontrager DuoTrap Ant+ / BT, with a new battery)
- pair with edge 820 / suunto 9
- calibration
Calibration worked as intented 0w -> 50w and 50w to 100w, then the pod start displaying power for about 3', and nothing 0w.
After 10' suddenly it worked again for somes minutes then 0w again.
Later i tried a new calibration while, and the same seems to work 3' mins then 0w, etc...
Re: Aeropod working only 5% of time
Obviously this is not correct...
Please post .ibr ride files and we will figure it out.
Johan
Post by Johan »
Thanks for your answer,
here is the 3 files from my yesterday test
iBike_10_17_2018_1731_3_Miles_HiDef.ibr
(120.75 KiB) Downloaded 335 times
iBike_10_17_2018_1753_5_Miles_HiDef.ibr
(206.59 KiB) Downloaded 305 times
iBike_10_17_2018_1824_9_Miles_HiDef.ibr
(307.76 KiB) Downloaded 295 times
Actually, it is your cadence sensor that is working only 5% of the time.
When cadence = 0, power = 0. Your cadence sensor is sending its signals intermittently. This is why you aren't getting good data.
I opened your ride files, highlighted the entire ride, then used the Isaac command "Tools/Repair/Repair Selection for missing cadence". All of your power data was there, in all three ride files.
You need to move your cadence sensor magnet so that it is working consistently. This will fix your problems.
Johan_10_17_2018_1753_5_Miles_HiDef.ibr
(213.9 KiB) Downloaded 305 times
Johan_10_17_2018_1731_3_Miles_HiDef.ibr
(124.01 KiB) Downloaded 325 times
Johan
Post by Johan »
Thanks john for your help,
this is what i suspected BUT the strange part is that on my watch i get cadence from the pod 100% of time.
I'll make test with another bikepod.
You are using a combined speed/cadence sensor. Sometimes these are a problem.
Johan
Post by Johan »
Tested today with an old gsc10, and worked as a charm 8-)
Johan wrote: Fri Oct 19, 2018 2:45 pm Tested today with an old gsc10, and worked as a charm 8-)
