Crr for wide rims lower pressure
still-chasing
Quick question on CRR. As the new wheels are wider now and the required pressure is lower, does the value of CRR in the settings have to be manually change to .55? When I did my initial setup for Cal Ride, one of the options in the setup is the tire pressure. I set it to 90psi for my wider rim wheelset compared to 100psi using my older,narrower wheelset. This drops my CRR to .0047 compared to .0058 The lower psi now on new wheels makes them roll better. I actually have to drop the psi again to 85 after a test ride. Please advice what to do. Attached is the profile for 90psi
- new profile.ibp
- (410 Bytes) Downloaded 1062 times
still-chasing
Re: Crr for wide rims lower pressure
Yes they are for a road bike. Enve 3.4 SES rims. and continental grand prix 4000s II. The options I chose were, Tires-premium, Hoods elbow bent, tire pressure 90psi (but will drop it to 85psi).
still-chasing
Should I do another CalRide when i lower the psi to 85?
still-chasing
Finally found a sweetspot for my tire pressure. It's 80psi. They're 10psi less when I did my first CalRide. Should I do another CalRide? If so, please advise what settings to set before CalRide. Should I manually change the settings of the tire pressure and tire width in the setup menu? Also, do you suggest a new CalRide if my weight change 5lbs+/- from original Calride? Thanks.
My bike setup:
Road bike, Enve 3.4 rims 27.5mm wide, 23mm Conti 4000s, 80psi
My bike setup:
No, there's no need to do a new cal ride for the tires.
You can adjust your weight in the profile; you won't have to do a new cal ride.
still-chasing
