Can't sync Newton and Garmin Edge 820
blp
Post by blp »
I used to get the power from the N6 broadcast and picked up by my Garmin 820.
I made an adjustment in Isaac to ignore DFPM, and I can't say that caused the N6 not being visible to Garmin.
Garmin scans and the N^ is not found.
How do I set up to broadcast power data to Garmin Edge 820?
Also, how do I find the N6 ANT+ ID?
Re: Can't sync Newton and Garmin Edge 820
Do a completely new scan, making sure that your DFPM is off.
That should fix things.
blp
Post by blp »
I assume you mean a new scan in Garmin.
BTW, any info on my updated thread, "Always a tail wind!"?
Do a Newton scan with DFPM off. This will enable DFPM out on your Newton.
blp
Post by blp »
I deleted all PM and did a scan. N6 found.
