Watts come up late?
mxfarm
Watts come up late?
Post by mxfarm »
Watts aren't acting normal - had this on another ride the other day also, any thoughts?
iBike_09_10_2018_2036_13_Miles.ibr
(169.7 KiB) Downloaded 854 times
Re: Watts come up late?
The first 8 minutes of your ride, Newton is readjusting its internal angle. Did you bump it out of position? Make sure the mount cannot rotate.
If this is a solo ride, then your wind calibration is low. Try using the attached profile.
Mxfarm.ibp
(541 Bytes) Downloaded 883 times
mxfarm
Post by mxfarm »
No bump I’m aware of - it was a second profile for a diff bike, and yes a solo ride, w/out the braking on the beginning of the ride.
OK, then use the profile attached.
mxfarm
Post by mxfarm »
got a error when I try to export
OOPS, I missed that. Something is wacky in your profile.
Sorry, but you will need to do a new calibration ride.
mxfarm
Post by mxfarm »
Profile may be jacked up - but I’m thinking it has to do with switching bikes. Sat switched back to the other profile but the newton didn’t recognize it. Had to scan for sensors, which of course left my pervious profile active...
Any way to check if my newton has APS?
Of course I may not have got them square w/each other.
The profile you have needs to be updated with a new cal ride. APS should be on your Newton, but if your profiles are messed up it won't make much difference.
mxfarm
Post by mxfarm »
Tks John will do.
