Using AeroPod as a power meter
We've created instructions that covers this topic. Attached.
AeroPod_Power_090718.pdf
(1.12 MiB) Downloaded 628 times
syll1914
Re: Using AeroPod as a power meter
Post by syll1914 »
When i m using Aero pod with a DFPM ...my garmin will read DFPM power or Aeropod power?...if I will set from isaac to forget DFPM..whats happen?..can i see slope, wind in profile 1 for exemple...because i calibrated my aero with a DFPM for cda and reading too low...same like old power meter (DFPM) and i don t want to see my old powermeter power on my garmin because it s not accurate
1) AeroPod rebroadcasts DFPM power. Select Aeropod in your Garmin
2) Do NOT "forget DFPM" in Isaac. If you do you will no longer receive CdA information
3) You are seeing DFPM data on your Garmin. Post a ride file and we will take a look.
syll1914
Post by syll1914 »
Velocomp wrote: Wed Oct 24, 2018 8:54 am 1) AeroPod rebroadcasts DFPM power. Select Aeropod in your Garmin
if cda information come together with my DFPM on my garmin, i don t want this because it s something wrong with DFPM...all i want to see it s aeropod data, wind and slope...how can i do?
If something is wrong with your DFPM, do a new sensor pairing in profile 4, making sure that your DFPM is off. You will see AeroPod power data in your window.
reiskayser
Post by reiskayser »
Should Wind display in profile 4 with Garmin IQ (1030) without having or using a DFPM?
Yes, I believe wind speed and slope will display,.
syll1914
Post by syll1914 »
I rode today in rain and was some problems after a descend... wind - 0...power data 0 or 20-30 watts..later was ok, but i m guessing i have to make a new calibration, even in my room wind is -3 m ..slope also not so good..what s happen when you are in a heavy rain?
Rain can be a problem if there is enough of it to block the wind port. Please post your .ibr ride file.
Once the wind port is cleared all will be well and you won't have to do a new calibration.
syll1914
Post by syll1914 »
Velocomp wrote: Sun Oct 28, 2018 9:51 pm Rain can be a problem if there is enough of it to block the wind port. Please post your .ibr ride file.
first part i rode in a group, from the second climb i rode alone, problem start on descent
canyon_28_10_2018_1045_88_km_HiDef.ibr
(1.84 MiB) Downloaded 495 times
