I recently upgraded to firmware v6.40 and, after having some issues with my bike profiles in Isaac, decided to do a hard reset of my PowerPod. I then reset all the profiles in Isaac and basically started again.
I then set up two new profiles in Isaac, one for my road bike and one for my TT bike. I then went through the sensor pairing process and shortened O&B calibration rides for each bike a couple of hours apart to avoid any possible cross sensor pairing problems. All seemed to go well.
The issue I have is that the profiles for each bike, notwithstanding I gave them different names, show up as "Unsaved (type: Initial Setup)" when I connect my PowerPod to Isaac. When I view the details of each "unsaved" profile, they are the same - both have the set-up details of my TT bike.
In view of the above, I'm not sure if the power readings for my road bike reflect the original details I inputted (i.e. riding on hoods, bent arms etc.) or are from the details of my TT bike (i.e. riding on aero bars etc.).
I've attached two ride files. The 07-17-2018 ride is for my TT bike and the 07-19-2018 ride is for my road bike.
Any guidance you can give me would be much appreciated.
Regards,
Nick Bean
Profiles and Calibration After Upgrade to Firmware v6.40
- iBike_07_19_2018_1242_44_Miles.ibr
- (456.65 KiB) Downloaded 219 times
- iBike_07_17_2018_1916_10_Miles.ibr
- (84.79 KiB) Downloaded 244 times
Re: Profiles and Calibration After Upgrade to Firmware v6.40
We may have accidentally broken something in Isaac "Reset profiles" with the 640 release. We are investigating and will report back ASAP.
