I just noticed that both my two commuting rides from yesterday have odd looking elevation. As if I was continously below see level. When the morning ride ends and the evening ride starts it's just at the pier - 3 meters above sea level. Anyway to calibrate that part?
Elevation issue
Elevation issue
- iBike_06_28_2018_0712_22_km_HiDef.ibr
- Morning ride
- (454.63 KiB) Downloaded 317 times
- iBike_06_28_2018_1905_22_km_HiDef.ibr
- Evening ride
- (526.01 KiB) Downloaded 316 times
Re: Elevation issue
I did three things:
1) I loaded your morning ride into Isaac
2) I used the File/append ride file command to add the evening commute back into your ride
3) I used the Analyze/Analyze Device/Starting Elevation to correct the starting elevation to 35 meters.
The reason the elevation is "off" is because of a weather change. PP measures barometric pressure changes to infer elevation changes.
Corrected ride file attached.
- albafar_06_28_2018_0712_44_km_HiDef.ibr
- (801.48 KiB) Downloaded 297 times
Re: Elevation issue
Brilliant - many thanks John!
