Yesterday I was trying to find where I adjust my height. I was in Isaac/Edit/Edit Profile/Wireless ID to see if that was there. I clicked on Forget DFPM (it was paired to a Vector 2) as I no longer own the Vectors.
When I began my ride after, there was no power displayed, although speed and cadence sensors had paired. After a few minutes, it did begin to display, although the power was very low compared to the effort, but did seem to come around after a few minutes.
I thought the issue was because I clicked "Forget the DFPM" and looked an earlier profile and used the Power in ID. This changed the ID from 0 to 5124 and Type from 0 to 5.
Clearly this was the wrong thing to do! I started another ride this morning and the same no power displayed. I powered down the Newton then restarted and checked that I was in the right profile - I was. Again no power displayed, then low reading to OK in a matter of a couple of minutes. When I went to download the ride files, I received an error 6004 message and the Newton locked up.
When I did manage to download the files, the first short file was OK. The second, the one after the restart, was met with a time stamp error (as I've seen occasionally) and click to set the recommended time. It turned out to be a segment of yesterday's ride, yet the time in the file name was today!
In the meantime, I have removed the ID and Type back to 0 and 0.
How to correct my mistake?
I've attached both of today's.
I think I messed things up!
- iBike_06_03_2018_1312_1_km_HiDef.ibr
- (22.24 KiB) Downloaded 629 times
Re: I think I messed things up!
Here is the easy thing to do:
1) Make sure the profile in your unit is correct (weight, cal ride, etc)
2) Do a new sensor pairing. This will get rid of the DFPM data.
I did confirm the profile data - correct.
The N6 found the sensors and those functioned correctly before re-pairing.
I just did a re-pairing, all found. It showed DFPM Off.
Just rode up my 9% lane for a few seconds, and it displayed power immediately.
