Exitosa de calibracion
pedrogallo
Post by pedrogallo »
:roll: :roll: :roll: :roll: :roll: :roll: :roll: As you can see this route,¿ it's probably good? that you think it's a john because you can do laps, you could not do it all the way, thanks, I hope your attention, we're not experts, except to give pedals in......
PedroGallo_30_05_2018_1825_38_km.ibr
(465.57 KiB) Downloaded 352 times
PedroGallo_30_05_2018_1254_3_km_CalRide.ibr
(38.06 KiB) Downloaded 336 times
Re: Exitosa de calibracion
Your calibration is fine but I am concerned your unit is rotating on its mount. Please post images of your PP mounted on your bike: top, side, bottom and front views.
You have some kind of material between your handlebar and your mount. Your ride file shows your PP is rotating during your rides.
pedrogallo
if it is a field for which it does not move, it is precisely used for the contour video, it will be removed and tightened directly and the surroundings of the subsequent trip
