firmware update to 6.32
I just installed this and wanted to know how I can show the battery life on a Garmin 520. thanks
Re: firmware update to 6.32
1) On your Garmin, select "Power Sensor". This will be your PowerPod
2) Select "Sensor Details"
3) Select "About"
4) You will see your current Battery Status at the top of the "About" menu
A. "New" is greater than 90% battery charge
B. "Good" is 70% to 89% charge
C. "OK" is 35% to 69%
D. "Low" is 20% to 34%
E. Critical is less than 20%
3) Select "About"
- IMG_0370.jpeg (192.13 KiB) Viewed 11278 times
Re: actualización de firmware a 6.32
Hello:
how long does the battery last in each of the levels?
regards
regards
stewartclark2002
After updating to 6.32 this is what I'm seeing on my Edge 800. Is the Edge 800 not compatible with this change?
- image.jpeg (287.19 KiB) Viewed 11177 times
That's kind of like asking how long your flashlight batteries keep the light bright
How long the batteries stay at each level depends on the length of your rides, how charged the unit is when you start riding, and how long it has been since you last charged your unit.
If you start with a fully charged PP, you can ride for over 20 hours continuously.
speedyvelo
Thxs John
-=terry=-
-=terry=-
This is garmin 810
Does anyone know how to check this on the wahoo bolt?
I'm just about ready to retire my Garmin 810 and get a Wahoo Elemnt Bolt, so I'm curious about whether this data is accessible on the Wahoo Elemnt Bolt as well. Can anyone confirm that the PowerPod battery status can be displayed on the Bolt?
We follow the standard ANT+ protocol. I'm guessing Wahoo does, too; if so, you should be able to access the battery info in ELEMNT. Make sure your using the Wahoo in ANT+ mode.
stewartclark2002
Is there any news on this updates compatibility with the Edge 800?
I think this is up to Garmin, not us. We are providing the battery information according to their ANT spec. The bike computer manufacturer has to decide how (and if) to display the data.stewartclark2002 wrote: ↑Thu Jun 21, 2018 8:15 am Is there any news on this updates compatibility with the Edge 800?
