Single Speed Rigid 29er Calibration
andrewschear
Calibrated my PP on my Single Speed rigid this AM. Running 2.6"/2.4" tires. I've attached a slightly adjusted ride file, but I think it's quite accurate. If you're thinking of setting it up on your SS MTB, this would be a good place to start. Power was just where it should have been based on effort and terrain.
- SingleSpeed_rigid_2_4_tires_29er.ibr
- (575.97 KiB) Downloaded 247 times
Re: Single Speed Rigid 29er Calibration
Thanks, curious what gear ratio are you using? I will try on my SS, currently 34x20 ratio, using long 185mm cranks for extra torque, it's also a 29er and currently have it set as rigidfork, weight is 18.5 lbs.
