PowerPod not picking up DFPM signals
richiev
Post by richiev »
I've been hoping to use a PowerPod to do some CdA testing. I haven't had much success getting it to collect data from the DFPM though. I've tried connecting it to a couple meters. First was a single sided stages, second was a dual sided stages, and the final was a set of Vector pedals. All of those are highly reliably able to talk to my Garmin head unit.
It's been difficult / unreliable to get the PowerPod to pair with them, but with a bit of luck they will. I've then gone on a couple rides and the data files only have bits of power data in them.
I've attached one of the most recent files, just to illustrate the low amount of DFPM data in there. This ride data was from a dual sided Stages.
I've just realized I can merge the data from a Fit file in, which should mean I don't care that much anymore, since I can do the merge then do the CdA analysis afterwards, but it'd be nice if it all worked directly.
Any pointers?
iBike_04_18_2018_1105_15_Miles.ibr
(250.43 KiB) Downloaded 383 times
