Power only accurate on flat and when climbing
andrewschear
Post by andrewschear »
Jon,
It seems that my Powerpod matches my power on my smart trainer on a flat or climbing effort. When descending at all, the power is really high. The more the descent, the more it's off. In order to get the numbers good, I had to use a CdA setup for "drop bars" even though I'm on a tri bike. I suspect it's because my fit is not extremely aero. (aero pads about 1cm below seat). When set to tt, the numbers are 10-15% low (according to my same HR per watt on the smart trainer).
Attached is my calibration ride and a ride with some hill work. I'm not going to coast on a 1% descent, as that would put me at a huge disadvantage.
Also, the amount that Isaac said I climbed vs. my garmin is quite different, garmin said about 2,000 which coincides with google, and Isaac said about 1300.
Thoughts?
iBike_04_01_2018_0649_2_Miles_CalRide.ibr
(93.69 KiB) Downloaded 260 times
iBike_04_15_2018_0639_0_Miles_HiDef.ibr
(1.6 MiB) Downloaded 265 times
Re: Power only accurate on flat and when climbing
When I opened your ride file and saw the large downhill watts, before reading your post carefully I thought to myself "I bet he's on a TT bike". Turns out, that was a correct guess!
You weigh about 158, and I infer your height is about 5' 9". That would imply a CdA of about 0.25.
I adjusted your ride file for this CdA, and your downhill watts diminish significantly to normal values.
I don't have an explanation for the elevation gain difference.
Andrew_04_15_2018_0639_0_Miles_HiDef.ibr
(1.65 MiB) Downloaded 279 times
andrewschear
John,
Thanks, I'm 5'6", not sure if that'll make a difference.
I'll plug in the new value.
