Powerpod 0 power readings on garmin
karel_k
Post by karel_k »
I have similar problem what's described in the thread: Powerpod 0 power readings on garmin 520
I make sure that PowerPod is fully charged before each ride. But I have several times during a ride when I see 0 wats even my Garmin show cadence reading.
I am attaching my ride, can you have a look and help me to figure out what can be a problem?
Thank you
iBike_03_30_2018_1418_32_km_HiDef.ibr
(781.44 KiB) Downloaded 246 times
Re: Powerpod 0 power readings on garmin
You have frequent and severe speed sensor dropouts from your combined speed/cadence sensor (GSC-10?). This is messing-up everything.
If you want to try to continue to use your current sensor, then remove its battery, put it in backwards for a moment (to hard-reset the sensor) then reinsert normally. It probably is a good idea to replace the battery, too.
If that does not fix things I suggest you get magnet-less Garmin sensors. Put the speed sensor on the front hub of your bike and all will be well.
karel_k
Post by karel_k »
Hi John, thank you for the prompt reply and help (as always :D ) I was able to reset and adjust a little bit speed sensor on my bike today. It seems is working fine now.
I will definitely look for magnet-less sensor combination as you suggested.
Your support is amazing. I appreciate it.
