Calibration OK?
Calibration OK?
I think everything is working well, except sometimes riding downhill the unit seems to over-report. I ride a Fuji SL, climbing type road bike.
Re: Calibration OK?
I am also interested to see if I did the calibration correctly - I have attached the files.
What I find different is that the max power on Isaac (270W) differs from the max power on what my Garmin Fenix 5 recorded (572W) - quite a lot. Upon import I was asked to decide where I have located my cadence (above, below or cancel) - I chose cancel the closest to "no" I could thought of.
Re: Calibration OK?
Hi John
I recently replaced handlebar and garmin mount, had to recalibrate. Wind scaling for the profile is very high (more than 3). The "check calibration" did not change values that much.
Can you check my profile and calibration ride please?
Thank you in advance!
Max
Max
- SLR01_prof.ibp.zip
- (850 Bytes) Downloaded 253 times
- iBike_04_22_2018_1900_5_km_CalRide.ibr.zip
- (52.24 KiB) Downloaded 256 times
Re: Calibration OK?
Please post your .ibr ride following your cal ride.
You don't have to zip it up in order to post it...
