Please check calibration: power seems high?
Etupes25
Post by Etupes25 »
Hello,
I have just leveled the unit to have the letters horizontal using a standard level, and I went for a cal ride. Took me a couple of trials to have a clean in and out.
However, now my readings look pretty high. Can you please check everything is OK?
iBike_03_07_2018_0738_3_Miles_CalRide.ibr
(96.83 KiB) Downloaded 243 times
iBike_03_08_2018_1625_24_Miles_HiDef.ibr
(814.94 KiB) Downloaded 248 times
Re: Please check calibration: power seems high?
Your calibration is fine but somehow your Crr was way too high.
I fixed the ride and your profile. Load the attached profile into your PP and all should be well.
Etupes.ibp
(421 Bytes) Downloaded 248 times
Etupes_JRH_03_08_2018_1625_24_Miles_HiDef.ibr
(837.26 KiB) Downloaded 265 times
Etupes25
Post by Etupes25 »
Thank you very much for your fast answer. I will upload right away and test it out!
