Re-Calibration?
Hi can anyone help with this please, I am intending to relocate my PP from on the bars to an out front mount using a combination Garmin Gopro mount. I think I read somewhere tat it's necessary to re-cal after this. could somebody walk me through what I need to do? Many thanks.
Re-Calibration
Re: Re-Calibration
1. Attach your PP to Isaac software.
2. Go to "Device/Setup Device..."
3. On the last step of the Setup Device wizard, select "Best Accuracy"
4. Do an out-and-back calibration
grahamtballard
Re: Re-Calibration
Brilliant thanks, I’ll get onto that as soon as the mount gets here. That all looks fairly straightforward, hopefully I’ll be able to do it OK.
Thanks again for your help.
grahamtballard
Re: Re-Calibration
I think I may have finally got this right now, it did come up on screen as a successful cal ride and the short test ride I did straight after seemed closer to the sort of power figures I would expect. I have attached the two rides from today for you to double check for me if you would. I also have a question, if I have it right now would I need to do another cal ride if I lose some weight or re appraise my FTP and change them in the edit settings window?
Thanks for all your trouble.
- iBike_01_17_2018_1114_42_km.ibr
- (325.63 KiB) Downloaded 699 times
- iBike_01_17_2018_1104_4_km_CalRide.ibr
- (42.31 KiB) Downloaded 744 times
