Calibration Ride
grahamtballard
Calibration Ride
After having mounted my Powerpod and pairing it with the sensors and head unit I set out for a calibration ride and I am not sure if I did it correctly. As I set out on my ride I pressed the button thinking I had just switched it on. It almost immediately started reading the calibration percentage, when it got to 50% I expected to have to stop and turn around but it just carried on increasing the percentage. After it got to 100% the light briefly flashed red/green I think then it just started giving power figures. As this is at odds with the instructions supplied I am concerned that I have done something wrong, or has the calibration process changed?
Re: Calibration Ride
If you were riding uphill, or slowly, at the 50% point the unit would have continued.
You can post a ride file from after your cal ride and I will look at it.
grahamtballard
Thanks for coming back to me so quickly, I'm not absolutely sure if I have done this right but I think I have attached the ride files, there seems to be a lot for just one short ride. Also I should have said in my original post, I did read on the DC Rainmaker test that an out and back ride was no longer needed that's why I was a bit puzzled. Having said all that the devise did seem to be reading my power OK.
- iBike_12_29_2017_1427_2_km.ibr
- (19.46 KiB) Downloaded 804 times
- iBike_12_29_2017_1433_26_km.csv
- (348.91 KiB) Downloaded 795 times
- iBike_12_29_2017_1427_2_km.csv
- (29.13 KiB) Downloaded 877 times
grahamtballard
OK sorry, I hope I got it Right this time!
- NewtonSampleRide_HiDef.ibr
- (1.43 MiB) Downloaded 842 times
- iBike_12_29_2017_1433_26_km.ibr
- (196.34 KiB) Downloaded 791 times
- (19.46 KiB) Downloaded 775 times
Your cal ride did not work properly, so I used the "Check Calibration" command to fix things.
Load the attached profile into your PP and all should be well.
- Willer.ibp
- (507 Bytes) Downloaded 780 times
grahamtballard
Many thanks for your help with this John. Ill try and load it up as soon as I can.
grahamtballard
Hi I think I am getting there now but I have one quick question. Is it necessary to re calibrate my PP every time I make a minor adjustment in my settings?
I'm not sure what settings you are adjusting, nor how minor they are. Please provide examples and I will let you know.
grahamtballard
I adjusted the weight as I had estimated it at first I also altered the ftp as I didn’t notice it when setting up .
