PowerPod FW 6.26 is available
PowerPod 6.26 does two things:
1) for all PowerPod units, 6.26 adds a new, “turn off PowerPod manually” feature.
To turn off PowerPod manually, click the PP button 5 times in a row. Status light will then show solid green, then yellow, then red, then turn off. When the light turns off PowerPod is put to sleep, the current ride file is saved, and a new ride file is started.
Note that the "automatic turn off" feature remains unchanged: after 20 minutes of complete inactivity, PP turns off and resets the ride file.
2) Corrects a problem with some PowerPods manufactured in mid-2017 where the “yellow” color of the status light appears reddish or amber. After applying the FW update, the yellow color is restored
FW 6.26 is available through Isaac: "Device/Check Online for Firmware update..."
optiplus
Re: PowerPod FW 6.26 is available
Post by optiplus »
You are the best in updating and solving problems, as well as being able to listen to the needs of users and manage to implement those needs, thank you very much
optiplus wrote:You are the best in updating and solving problems, as well as being able to listen to the needs of users and manage to implement those needs, thank you very much
We really appreciate your comment!
