In almost all the routes predominates, I think artificially, the tailwind. Could it be due to the wind scaling present in the profile? Should I do another calibration? I made a couple of changes regarding the profile obtained in the round trip (CdA, and Crr) but did not modify the Wind Scaling
Any suggestions?
Regards
Tailwind
Tailwind
- Viper final.ibp
- (539 Bytes) Downloaded 289 times
- Viper initial.ibp
- (414 Bytes) Downloaded 325 times
- iBike_10_13_2017_1708_59_km_HiDef Santa Bárbara Viper final.ibr
- (1004.69 KiB) Downloaded 318 times
Re: Tailwind
Please check the archives. I'm pretty frustrated
Regards
Regards
Re: Tailwind
Assuming that this is a solo ride, then your wind scaling is incorrect.
I've made an adjustment to your profile.
Load this into your PP and post your next ride file.
- bfermarJRH_10_13_2017_1708_59_km_HiDef%20Santa%20B%C3%A1rbara%20Viper%20final.ibr
- (1.22 MiB) Downloaded 335 times
- bfermar.ibp
- (719 Bytes) Downloaded 294 times
Re: Tailwind
The route was made with two more companions. I guess that's why the drafting strokes appear.
I'll try the new profile.
Thank you very much
Thank you very much
Re: Tailwind
I send another route with another profile, for a second bike, which suffers from the same problem with the tailwind. Interestingly, the incorrect wind scaling is very similar in the two profiles, after the O & B calibration.
Please analyze this second profile.
As soon as I test the first corrected profile I will upload the test route
Many thanks
Regards
Many thanks
Regards
- iBike_10_15_2017_0907_102_km_HiDef Puebla Giant.ibr
- (1.61 MiB) Downloaded 317 times
- Giant 3.ibp
- (539 Bytes) Downloaded 334 times
Re: Tailwind
Commenting on this second route, that on returning (kms 50 to 62), the wind against was quite strong, something that is not reflected in the route file
Re: Tailwind
Please do a short (10KM) out and back, solo ride. This will be the best thing to use for analysis.
Re: Tailwind
I am sending you the latest O & B calibration for one of the bikes. Please check the files, is everything ok?
Is the wind sensor working well?
Regards
Regards
- iBike_10_24_2017_1825_22_km_HiDef.ibr
- (508.85 KiB) Downloaded 348 times
- iBike_10_24_2017_1815_4_km_CalRide Giant 6.ibr
- (91.03 KiB) Downloaded 287 times
Re: Tailwind
It looks like you were riding on a windy day. If this is correct, then you are fine!
