Hello
I recently updated powerpod firmware and issac software latest version.
Riding files after that, every time I launch PStroke analysis, it shows only example file not actual pop-up window.
but when i open riding files before i updated, it shows all waste motion analysis just like before.
do i need to unlock feature again?
Thank you~!
Firmware upgraded problem...
- PStroke error2.jpg (207.25 KiB) Viewed 28732 times
- PStroke error.jpg (290.98 KiB) Viewed 28732 times
Re: Firmware upgraded problem...
Please post a .ibr ride file that illustrates your problem.
Please find attached .ibr file.
super thanks!!!
super thanks!!!
- iBike_10_05_2017_1507_154_km_HiDef.ibr
- (2.38 MiB) Downloaded 846 times
PowerStroke requires cadence data.
The problem is that your cadence sensor ID is not stored in your profile.
Do a new pairing with your PP, making sure first that your cadence sensor is definitely ON. Ride around a bit, until you see your cadence data on your Garmin, then do a pairing.
After that you should be OK.
