I am trying to correct the elevation settings in my powerpod. I have tried to use Isaac ->tools>repair> set atmospheric pressure but it will not accept my personal wunderground station. Airports are much lower than me but it doesn't seem to use those accurately. The simplest would be to enter my stating elevation into isaac and let it do the adjustment like my edge 800 does. Anyway how can I adjust my elevation.
Thanks in advance
Setting Elevation correction
- Can't figure out how to use this
- pressure.JPG (32.75 KiB) Viewed 4429 times
- Peak should be 450 ft
- elevation.JPG (10.32 KiB) Viewed 4429 times
Re: Setting Elevation correction
Use the Isaac command Analyze/Analyze Device Settings/Starting Elevation"
Thanks it worked!
