No Elevation Readings
stewartclark2002
Post by stewartclark2002 »
Can someone have a look at this ride file. It shows little change in elevation for the full ride (not the case) but clearly records changes in slope.
The ride was about 40 miles long and strangely the file name suffix suggests 0 miles. Any help would be appreciated.
Stewart
Power Pod_14_09_2017_1003_0_Miles.ibr
(430.68 KiB) Downloaded 289 times
Re: No Elevation Readings
If you look at the very end of your file you will find a peculiar slope spike. I suspected that this was a data error, so I used the "File/Split File at cursor" command to get rid of the spike.
Sure enough, the rest of your file was fine!
Attached.
Power%20PodJRH_14_09_2017_1003_39_Miles.ibr
(423.48 KiB) Downloaded 302 times
stewartclark2002
Thanks for the prompt reply - and solution.
Stewart
