Cda is correct?
bfermar
Cda is correct?
Post by bfermar »
In view of this route, made with the profile I send you, do you consider that the Cda used is correct? How to know? I measured 172 cm and 70 kg in weight and I go in hoods, but also in drops, as far as possible
Regards
iBike_09_13_2017_1807_27_km_HiDef.ibr
(523.41 KiB) Downloaded 252 times
Viper 9 BF1.ibp
(531 Bytes) Downloaded 258 times
Re: Cda is correct?
Your ride file looks fine, and the CdA for your height and weight is ok.
