Excess power on downhills
ortos
Post by ortos »
I am a powerpod user. I have calibrated the device several times and I never get the "true" power on the downs.
I send you the calibration file and some bike ride.
Could you verify if I have something wrong?
Thank you.
iBike_08_23_2017_1830_58_km.ibr
(415.3 KiB) Downloaded 219 times
iBike_08_21_2017_1932_69_km.ibr
(509.15 KiB) Downloaded 200 times
iBike_08_19_2017_1708_4_km_CalRide.ibr
(40.53 KiB) Downloaded 211 times
Re: Excess power on downhills
If you go into any kind of an aero tuck on downhills, PP will read high. This is one of the characteristics of this device.
You're descending some pretty steep hills; if you let gravity do the work you will go just about as fast, and you won't have to pedal.
ortos
Post by ortos »
when I am descending small inclinations (3-5%) and I am pedaling PP given values are disproportionate.
3-5% is steep enough to cause excess watts if you're in a tuck
ortos
Post by ortos »
okay. Then once analyzed the routes that I have attached you think that the values that the powerpod delivery are correct? or will you need any change in any factor?
I would not change anything
ortos
Post by ortos »
thank you very much for your attention
