Hi! I was just trying the trainer mode on my powerpod. I have an Elite Novo Force trainer, but I can't find it on the list provided. Is there any planned support for this? Otherwise, wich trainer profile is similar to the Elite Novo Force?
Thanks in advance, Martin
Elite Novo Force support?
Re: Elite Novo Force support?
This is a new one to us. Please ask the manufacturer to provide a speed/power curve and we can update our list.
Dear John,
Thanks for your answer! Here is the information I found on the internet, if you need further data please let me know.
http://www.powercurvesensor.com/cycling ... er-curves/
Please check the Elite Novo Force section, for resistance levels 3 and 6.
Thanks in advance.
Cheers,
Martin
Thanks in advance.
Cheers,
Martin
Dear John,
Attached is the curve sent by Elite, in case you need more detail.
Novo Force 8 Livelli.pdf- (172.91 KiB) Downloaded 1571 times
I have the same need. I use trainer Elite Novo Force 8 and like to estimate the power via Powerpod. Is there already a fix for it? Thanks, Adalberto
Alguien me puede ayudar como vincular mi power pod con Garmin 520?tengo un rodillo elite novo force 8.
Qué pasos a seguir???tengo sensores de cad. Y velocidad.
Gracias
Gracias
In Isaac the Tacx Satori Level 4/10 is very close!
- Screen Shot 2018-10-31 at 7.32.22 PM.png (122.61 KiB) Viewed 40632 times
