trouble merging and synchronising
beng88
Post by beng88 »
hi,
i am trying to merge gps & heart rate data into my powerpod's file. i get some weird results when isaac tries to sync them. i uploaded the gps data to strava, no worries, but in isaac it shrinks the length. can i sync it manually?
any help is appreciated, thanks.
iBike_08_20_2017_1515_55_km.ibr
(601.2 KiB) Downloaded 456 times
hills_ride 20_08 exported from strava.tcx
(1.37 MiB) Downloaded 559 times
Re: trouble merging and synchronising
I looked at your two files.
The clocks in the two files seem to be running at different speeds, creating the mismatch problem.
There is nothing suspicious in your PP file; that is, all the data is completely normal.
Have you had this problem with other rides?
beng88
Post by beng88 »
I went on another ride today and i'm getting the same problem. hmmm
