Power drops to zero even while pedaling
GooseRider
Post by GooseRider »
Noticed today that power drops to zero on a regular basis even while pedaling. Does that make sense? Added today's ride file. Was running some short intervals and ended riding hard for a while.
Some examples: 0:03:23; 0:07:25; 0:08:57; 0:12:26; 0:27:05; 0:34:55; 0:40:01; 0:46:14; 0:55:31
Morten
iBike_08_13_2017_1407_29_km_HiDef.ibr
(600.26 KiB) Downloaded 266 times
Re: Power drops to zero even while pedaling
Most of the places you pick out have zeroes only for 1 second.
3:23--no explanation
7:25--gear change
8:57--you're on a downhill
12:26 downhill
27:05 no explanation
3455--cadence slows a bit
I did not look at the rest of them...
The "culprit" is that you have your PP set to transmit with zero filtering. This is a super-twitchy mode. And, if you're seeing these "zeroes" on your bike computer screen, then you have your bike computer filtering set to super-twitchy as well.
Either set your PP to 3 second averaging, or your bike computer. That will take care of the problem.
GooseRider
John,
Thank you for looking through it. You are right, my PowerPod is unfiltered. On my bike computer, I run 3s averaging on most of the screens. I have one screen setup to show unfiltered, 3s, 10s, and power zone. I was playing around with finding my maximum endocrine (5s) power. Now wonder about the accuracy of short time period power measurements. Like 5s and 10s. 1s out of 5s could have quite an impact.
What is the minimum recommended time period where the PowerPod could be considered accurate? 5s? 10s?
Morten
The truth is that all PMs, with the exception of PP, filter (smooth) their outputs. PP is the only PM that lets you see truly "raw" data.
PP is not less accurate when you set its filtering to 0; it's just that you see the raw, not filtered, data.
The data PP records has zero filtering, no matter what the smoothing setting is. So, you can do your 5 second analysis in Isaac, irrespective of smoothing setting.
I would probably set smoothing to 1 or 5 seconds, just so you don't go crazy trying to look at your bike computer data. Then, I would do the analysis in Isaac.
