Stem mount Fouriers Garmin/Gopro
optiplus
Post by optiplus »
I have the Fouriers HA-S014 stem mount that I want to use with Powerpod.
http://www.fouriers-bike.com/en/pro.php ... cid=28&f=5
With this mount watt´s the configuration to choose, handlebar or stem?
Regards
Re: Stem mount Fouriers Garmin/Gopro
In the "Device/Device Setup" wizard, choose the Front Mount position.
Screen Shot 2017-07-29 at 10.50.46 AM.png (74.96 KiB) Viewed 9756 times
optiplus
Post by optiplus »
Thanks ;)
optiplus
Post by optiplus »
Hello John,
Another question ;)
Since I will use a different mount, the correct way to mount it is as it is in the attached photo?
https://photos.app.goo.gl/hEUHcNyzQcga9io02
Regards
You want PowerPod to be approximately level, but as long as it is within +/- 20 degrees of level you will be fine.
