Watts seem low
Watts seem low
Hello,
I am a new user and I'm wondering if I have things set up properly as I find my watts are pretty low. Last night I pushed pretty hard and while it was reflected in my average speed, my watts are still low. I've been reading other posts and my Crr looks normal as does my wind scaling. I've attached my ride from last night and am hoping someone can assist.
Yo
Yo
- iBike_07_17_2017_1832_31_km_HiDef.ibr
- (572.24 KiB) Downloaded 245 times
Re: Watts seem low
I agree your watts are low. You can fix this with an out and back calibration.
Please see these links for instructions:
http://www.ibikeforum.com/viewtopic.php?f=12&t=4097
http://www.ibikeforum.com/viewtopic.php?f=12&t=3852
Re: Watts seem low
Thanks for the help. I will try that in the next few days.
This URL isn't working for me. I get a URL signature expired error message.
VC-Phill wrote:Hi All, here is a finalised and polished up PowerPod O&B manual...
https://scontent-lga3-1.xx.fbcdn.net/v/ ... e=590224CD
Re: Watts seem low
I did the out and back this morning. It looked like it did as described in documentation but when I got to the 100 it cycled back to 0 and started counting up again. At this point I hit the button, probably a few times. it then locked up at 50 and stayed there no matter what I did. I would get the flashing green/red and if I pressed button, it would turn orange again so thought perhaps it wanted to continue on but it just stayed at 50 even with powering it completely off and back on. There are a few files on the device but I think this is the one that captures the out and back ride. I don't know if it's valid or not.
- iBike_07_20_2017_0624_3_km_HiDef.ibr
- (79.48 KiB) Downloaded 234 times
Re: Watts seem low
I just completed another O&B with the same results. I re-read the instructions before I left and really wanted to make sure that when I hit 50 that I saw the red light before stopping and turning. The test goes exactly as described but when I get to 100 it does not start showing "normal" watts. It blink red several times and when I turned to head home, it started flashing red/green again and if I pressed the button, it flashed orange and stayed at 50. I'm attaching the 3 files that I ended up with. Thanks in advance for your support.
- iBike_07_21_2017_1918_1_km_HiDef.ibr
- To starting place
- (20.69 KiB) Downloaded 226 times
- iBike_07_21_2017_1931_1_km_HiDef.ibr
- Ride home after O&B
- (20.49 KiB) Downloaded 214 times
- iBike_07_21_2017_1921_4_km_HiDef.ibr
- O&B
- (75.69 KiB) Downloaded 211 times
Re: Watts seem low
Something is wrong. Please email technicalsupport@velocomp.com for next steps.
Re: Watts seem low
Thanks for your help. I emailed them this morning.
Re: Watts seem low
Hi again,
I expect that my repaired/replaced powerpod will arrive any day now. After charging and installing, do I just do the regular 5 minute calibration ride or is it better to do the Out and Back?
Re: Watts seem low
I would take a little bit of extra time and do a new O&B calibration.
Make sure you go through the complete sequence, including sensor pairing.
Re: Watts seem low
Did my O&B today. Does this look good to you?
Re: Watts seem low
Your temperature appears to be too far off. Please email technicalsupport@velocomp.com for next steps.
