wrong speed with new sensors
dieterstruye
Post by dieterstruye »
I'm struggling to have the right speed on my newton device.
I used to work with the original ibike sensors and everything went well. On the same bike, using the same profile, i installed now sensors that are installed internally in the bike. (trek)
My newton is finding these without any issue, i did a cal ride. But the speed is wrong & fluctuating very strongly, as a consequence power & distance are also wrong.
The sensors & magnets are well installed & battery is ok.
As soon as i put back my original sensors on the bike, it's correct again.
What could i do to get a correct speed measurement?
thanks!
Dieter
Re: wrong speed with new sensors
The problem is that your Trek sensors do not transmit a very strong signal, and because they are mounted internally in the frame, the signal is weakened even more, so that the Newton is receiving their transmissions only intermittently. This is what causes the sporadic power and distance calculations (speed dropouts).
You should continue to use the original sensors with your Newton.
dieterstruye
ok thanks.
So no real solution but going back to original sensors which is fine.
However, any idea on where to get now ibike sensors to use with my TT bike & mountainbike? I cannot find any on the internet to buy seperately ...?
The Garmin magnet-less sensors work very well.
Just be sure to put your speed sensor on the front hub of your bike
dieterstruye
thanks a lot for your quick replies!
to be completely sure : the original ibike sensors are not for sale if i understand well? so as an alternative i go for the garmin ones.
thanks!
We have the original iBike speed/cadence sensor. Please email technicalsupport@velocomp.com if you are interested.
