TT to Road Bike
DavidK
TT to Road Bike
Post by DavidK »
John, I want to put the PowerPod on my road bike but using the same wheels and speed sensor as I've been using on my TT bike. I think I read elsewhere in the Forum that because the sensor is the same I don't need to do a separate calibration when moving the PowerPod between bikes. Is this correct even though the riding positions are so different between the TT and road bike?
Re: TT to Road Bike
You need to set up separate profiles for your road bike and TT bike.
Use the Device/Device Setup menu to create both profiles. NOTE: there is a bug in the Mac version of Device Setup. If you're using a Mac please respond below and I'll tell you the workaround.
Because you are using the same sensor on both bikes you'll need to manually switch between profiles, using Isaac.
DavidK16
Re: TT to Road Bike
Post by DavidK16 »
Thx for the quick response. Not using a Mac.
