Powerpod calibration and power numbers
michalm
Post by michalm »
Hi there,
I have been using Powerpod for just over a week now and I am hearing from my colleagues that the power data I am gettign are overestimated.
In particular, I attmpted a 2x8 min FTP test the otehr day and while I have only managed to do one half of that test I got an average power on those 8 minutes to be ca. 305 W. Now, I will not calculate my FTP from this as it was only half of the necessary test, but the range of FTP seems quite high (275 Watt-ish) for a newbie like myself. Perhaps I did something wrong with the calibration?
I attached here the calibration ride file as well as the actual ride with the 8 minute effort.
Could you please comment? Is there something off about my calibration? I am 82 kg and my bike is about 9 kg
M
iBike_06_17_2017_1238_30_km.ibr
(221.44 KiB) Downloaded 217 times
iBike_06_17_2017_1228_5_km_CalRide.ibr
(42.74 KiB) Downloaded 234 times
Re: Powerpod calibration and power numbers
You may be a newbie to power, but it's clear from your ride file you aren't a newbie cyclist...
Your PP is properly calibrated...all its settings look correct.
You averaged 34KM/h on a flat course, with a head wind!
I think your estimated FTP is OK, but if you can you should probably do a full 20 minute FTP test. For someone of your stamina it will be a more meaningful measurement.
michalm
Post by michalm »
Thanks John!
Michal
