Isaac fails to connect to PP most of the time
tbrucebowers
Post by tbrucebowers »
I have only been able to connect my PP to Isaac maybe 4 or 5 times. I have reinstalled the drivers numerous times, and it seems to work once and then fail the next time I open Isaac. Can't seem to connect at all now. The USB cable works as a charger, so I'm assuming it is good and has a good connection. Have tried numerous cables and USB ports on the Mac. All fail the same.
Macbook Pro
OS X El Capitan 10.11.6
Isaac 4.1.0
PP latest firmware (can't check number because can't connect)
Looking forward to using this wonderful device more fully, T Bruce
T Bruce Bowers
Re: Isaac fails to connect to PP most of the time
Please contact technicalsupport@velocomp.com for next steps.
tbrucebowers
Done. Thanks John.
T Bruce Bowers
tbrucebowers
Got a new USB connector installed in the Powerpod under warranty (Thanks!), and I get totally reliable USB connections now,BUT I still can't download ride data. I get the standard "6004 Error" window. No ride data is downloaded. I can communicate with the PP fairly reliably for most operations, and get a list of rides that look valid, but ride data downloads all fail.
What do I do?
I have installed the drivers numerous times, and now can't even find instructions for doing it again.
OS X 10.11.6
Macbook Pro
4 Gb RAM
Isaac 4.1.0
PP firmware 6.22
T Bruce Bowers
