Hello:
In the profile I have created, with which I made the O & B calibration in March, I changed the weight of the cyclist (including clothes, phone ...) to 67 kg and the bicycle I changed to 9.3 kg, 76.3 kg total. When I did the calibration had a total weight of 78 kg. The height of the cyclist is the same, 178 cm. I attached the file to a route I've made to see if the PP has worked well with the new changes or if I would have to calibrate it again. Yes I have noticed that it seems to mark less power. I made the changes from: "edit profiles" - "send to device"
Thanks and best regards
Route verification
Route verification
- iBike_06_04_2017_0837_143_km.ibr
- (978.92 KiB) Downloaded 313 times
Re: Route verification
I checked your ride file and your profile.
Everything appears fine and I would not change anything.
