mulitiple bike setup ?
Bluther333
Post by Bluther333 »
I have called ,searched , studied watched videos and tried on my own many times for months to get multiple bikes set up in my powerPod and just cant get it correct ? help Please I am spending hours with set up and still having problems getting multiple bikes . I think I am close and don't want to mess this up again . somehow I have the same bike on two different profiles
how do I know what profile to delete to make room for another bike .I have totally started over many times and always get back to this point . I want four different bikes . Also when viewing a ride how do I know what bike I am looking at ? Thanks for any help !
Multipal bikes.GIF (20.28 KiB) Viewed 5181 times
Re: mulitipal bike setup ?
Are you saying that you have four different bikes, for which you are trying to create a unique profile for each?
Do you have ride files for each of these four bikes? If so, please post one .ibr ride file, from each bike. This will allow me to sort things out for you.
Bluther333
Yes I want 4 bikes but so far just trying to set up the first three , allez sprint road bike , epic race mtb and serios TT bike . I will add my Roubaix road bike next . When I am looking at past ride files I cant tell what bike profile I am viewing ? when I set profiles in Newton I take a calibration ride and it counts down from 1 to 100 and looks like everything is ok . But the next day when I go to ride I get the yellow light and it wants to count down again somehow I am doubling up on my profiles ? I am sure it is user error but I am starting to get frustrated after several attempts at this . thanks for any help . I have a time trial tomorrow and have several riders interested in the powerpod data so I want to get it right .
05_14_2017_1209_14_Miles_Epic Cal_ Bethal_HiDef.ibr
(526.15 KiB) Downloaded 303 times
Bluther333
TT Bike Ride File
05_10_2017_1749_17_Miles_serios cal_HiDef.ibr
(453.49 KiB) Downloaded 317 times
Bluther333
Allez sprint road bike ride file
05_08_2017_1732_39_Miles_sprint depo social _HiDef.ibr
(1.01 MiB) Downloaded 323 times
Re: mulitiple bike setup ?
Please do the following:
1) Attach your PP to Isaac
2) Go to "Device/Setup/Reset Profile_Device"
3) Click on the "Reset Profile 1" button. You will get a confirming message
4) Repeat step 3, for profiles 2, 3 and 4
5) You have now reset your PP so that all 4 profiles are empty.
6) Go to Edit/Edit Profiles
7) Select all of the profiles shown in your window, and delete them with the "Delete" button
8) Click "Accept"
9) Open Edit/Edit Profiles. You should now have an empty profile window.
10) There are 3 profiles attached to this post. Place each profile on your computer's desktop
11) Go to Edit/Edit Profiles
12) Click the "Import" button. Import the three profiles, one at a time. As you import each profile, you will find it added to your Profile window
13) You now have your 3 profiles in Isaac.
14) In the Edit/Edit Profiles window, click on the *Set Active Profile in Device" drop down menu to profile 1.
15) Highlight the bike profile you would like to put in profile 1 (for example, Allez). Click the "Send to Device" button. The Allez profile will now be stored in profile 1 of your PP
16) Select profile 2 using step 14. Highlight another of your bike profiles, then click the "Send to Device" button.
17) Repeat the above steps for your third bike, to place its profile in Profile 3 of your PP
You will now have your three bike profiles stored in your PP.
Your speed sensor IDs are unique. So, when you want to ride "bike 2" wake up the bike 2 speed sensor ONLY (do not awaken the speed sensor on bikes 1 and 3). Then, wake up PP. After a few moments your PP light should go solid green, indicating that it has found profile 2, for bike 2.
The same process will apply when you ride bikes 1 or 3. Just make sure the only sensor awake is the one you want to ride.
Epic.ibp
(433 Bytes) Downloaded 341 times
TT.ibp
(429 Bytes) Downloaded 311 times
Allez.ibp
(437 Bytes) Downloaded 309 times
Bluther333
Thank you for the information. I have the powerpod mounted to the areo bike for tonight's time trial .thanks for the help
