I used my PP tonight in a crit race, before the race earlier in the day i did an out and back calibration. I didn't analyse this calibration using the Isaac software. I have checked the data back and the power out put is far too high, i have tweaked the calibration. i think after the tweaks its giving a more realistic average wattage etc.
could someone check the 2 files, i have attached the non adjusted file and the adjusted file. i tweaked the crit race file because it started in the same place and of course finished in the same place.
thanks again
Andrew
First circuit race with PP.
andrewkerr1991
- crit race tweak.ibp
- (578 Bytes) Downloaded 261 times
Re: First circuit race with PP.
The only file posted is the profile file.
Please attach the .ibr ride file.
andrewkerr1991
Apologises John, Please find attached now.
that is the tweaked file using the calibration analyse.
i cant seem to find the file before before i made the adjustments.
Hope this helps.
Cheers
Andrew
Hope this helps.
Cheers
Andrew
- iBike_04_27_2017_1921_6_Miles.ibr
- (89.03 KiB) Downloaded 272 times
