If you're new to Isaac software (you have never installed Isaac on your computer), these instructions will help you install Isaac, and also take advantage of the new Simple Setup procedure that was introduced with version 4.1 of Isaac.
Let us know what you think!
NOTE TO "OLD HAND" ISAAC USERS: the Simple Setup procedure can be accessed through the Isaac command "Device/Setup Device..."
Isaac Simple Setup
Isaac Simple Setup
Isaac Simple Setup041417_red.pdf- (703.75 KiB) Downloaded 700 times
