I read somewhere in the documentation that a new profile created through Isaac would be automatically recognized by the device. I'm curious about what triggers that. I will be setting up a second bike, and will have multiple garmin speed sensors that I'll use on one bike. How do I make sure I'm getting appropriate readings?
Bike 1 has the new Garmin cadence sensor, and will have two wheels with their own sensors: both tubular, one with 25mm training tubs, the other 25 or 27 mm premium tubs.
Bike 2 has another Garmin cadence sensor, and will have two sets of wheels where I'll likely just move the wheel sensor. One tubular w/25mm tires, the other clinchers with either 28 or 32 mm tires.
My current bike 1 is on profile 2 configured for the 25mm training tubs. After I have another profile set up for bike 2 with one set of wheels when do I manually need to change the active profile through Isaac?
Multiple bikes, multiple sensors, auto profile selection
flahutewannabe
Re: Multiple bikes, multiple sensors, auto profile selection
The key factor is the speed sensor. PP assumes you will have a DIFFERENT speed sensor on each bike.
If you do, then after you create profiles for each bike, PP will "tune in" to the speed sensor that is awake.
flahutewannabe
Got it; thanks. Looks like I should take a minute when I want to change wheels and swap sensors across the sets to keep the sensor/bike/PP all in sync.
That's a cheaper proposition, too
will allow me to put the third speed sensor on bike #3 (29er) or #4 (fat bike) and use my PPod with them too. I am interested in the fat bike thread and where that all ends up. Probably a good topic for a separate piece of documentation once everything is resolved.
