Isaac 4.1 has been released
IMPORTANT: ISAAC 4.1 DOES NOT INSTALL ON WINDOWS COMPUTERS RUNNING WINDOWS VISTA, XP, OR BEFORE
Isaac 4.1 contains several important improvements, mostly directed at fully incorporating PowerPod into Isaac's operation:
1) PowerPod, Newton, and iBike power meter are now referred as "Device" throughout the menu items and the program itself. This should make Isaac usage far simpler.
2) Newton Tracker is now referred to as GPS Tracker
3) Instructions in the Help menu have been updated, as appropriate
NEW FEATURE, "SIMPLE SETUP"
For new Isaac users only (Isaac has never-before been installed on the computer) the program launches in "Simple Setup" mode.
Simple Setup allows a user to dial-in their device, without referring to ANY of the main screens or menus of Isaac.
The Simple Setup mode is identical to the "Device/Setup Device" wizard found in Isaac.
After completing Simple Setup, the user has the choice of keeping Isaac in Simple Setup mode (in which case, the program quits) or going into full Isaac mode (normal Isaac operation).
