How can I change a sensor?
Sergioperi
Post by Sergioperi »
Good day,
I would like to change of my main profile the HRM sensor to other HRM band . because I can't have two sensor linked, isn't it?
How could I do this? I'll do a half IRONMAN next Saturday, and i use to use a cycling hrm for training with my bike. But I have other one to run and Triatlon.
Regards!
romi
Re: How can I change a sensor?
Post by romi »
Hi!
Put your new HRM on you and do a new sensor pairing again. Should be enough. After that, to be sure, connect the PP to Isaac and, in your active profile, load the sensors ID from the PP (is a dedicated button in the sensors tab) to see if the old values was changed.
Stay safe and ride hard! :)
Sergioperi
romi wrote:Hi!
Thanks a lot!!! How could I do a new sensor pairing? Do I have to press-hold botton for 4 second, and automatically PP recognize all sensors including the new HRM band (Waking up all of them previously)?
Regardsss!! And thanks again :)
Yes, press-hold for 4 seconds, until the light flashes. That starts a new pairing process.
