Concerns over power readings
usedtobefaster
Post by usedtobefaster »
Hi
I've got concerns that the output from my PowerPod is too high by somewhere between 50 and 100 watts based upon RPE and heart rate readings. I've checked the profile for the bike and it looks right - 700c x 23c, about 90psi, total weight (rider and bike) 80kg, road setting was the reasonable asphalt option, rider position set at on the hoods with elbows bent option.
I was happy about the accuracy but my concern has been raised been raised since using a Tacx Flux and comparing the RPE when using this at 200W and the same RPE at 200W on the road, I realise that indoors RPE is often higher without the cooling effect of riding into a wind but I feel as though the difference is just too big which is leading to my distrust of the PowerPod output.
The file I've uploaded was from a gentle spin using only the little ring of a compact chainset.
Paul
road_27_03_2017_1631_23_km_HiDef.ibr
(453.35 KiB) Downloaded 284 times
Re: Concerns over power readings
You are using the "out of the box" settings of PP.
You might want to try an O&B calibration. This will give you a chance to refine your bike/rider settings, and also get maximum accuracy from your calibration.
usedtobefaster
Hi John
I've done the O+B cal ride now and adjusted my ride on the 27th using the adjusted profile and the ride metric look more reasonable, now for a few more rides to get a better feel for the new adjusted output.
thanks
Paul
road_27_03_2017_1631_23_km_HiDef_post_obcal_9p8kg.ibr
(466.04 KiB) Downloaded 331 times
Numbers do look much better
